Troubleshoot Files Invisible to Plex
Server Version#: 1.19.1.2589
Player Version#: 4.22.3
Issue: two episodes are totally invisible to plex, even in the logs:
E01 not found
E02 found
E03 found
E04 found
E05 not found
to rule out TV show mismatch. I created an “other videos” library from scratch and put this directory there
/Other Videos/Dynasties (2018)/Season 01/
Still no dice on E01 & E05, suggestions?
Grateful for your help
logs:
Apr 01, 2020 00:35:58.387 [0x7ff6ca2762c0] DEBUG - Scanner: Processing directory /Pool01/Plex Media Library/Other Videos/Dynasties (2018) (parent: yes)
Apr 01, 2020 00:35:58.389 [0x7ff6ca2762c0] DEBUG - Scanner: Processing directory /Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01 (parent: yes)
Apr 01, 2020 00:35:58.394 [0x7ff6ca2762c0] DEBUG - Looking for path match for [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv]
Apr 01, 2020 00:35:58.401 [0x7ff6ca2762c0] DEBUG - Added new metadata item (Dynasties) with ID 3861
Apr 01, 2020 00:35:58.402 [0x7ff6ca2762c0] DEBUG - Looking for path match for [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv]
Apr 01, 2020 00:35:58.407 [0x7ff6ca2762c0] DEBUG - Added new metadata item (Dynasties) with ID 3862
Apr 01, 2020 00:35:58.476 [0x7ff6ca2762c0] DEBUG - Looking for path match for [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv]
Apr 01, 2020 00:35:58.478 [0x7ff6ca2762c0] DEBUG - Added new metadata item (Dynasties) with ID 3863
Apr 01, 2020 00:35:58.555 [0x7ff6b3fff700] DEBUG - Matching 'Dynasties' (ID 3861) with agent com.plexapp.agents.none
Apr 01, 2020 00:35:58.594 [0x7ff6ca2762c0] DEBUG - Updating directory 'Dynasties (2018)' (ID 377) to time 2020-03-31 15:12:22.
Apr 01, 2020 00:35:58.594 [0x7ff6ca2762c0] DEBUG - Updating directory 'Dynasties (2018)/Season 01' (ID 378) to time 2020-04-01 00:24:08.
Apr 01, 2020 00:35:59.575 [0x7ff6b3fff700] DEBUG -  * Score: 100 (Dynasties)
Apr 01, 2020 00:35:59.575 [0x7ff6b3fff700] DEBUG - Setting GUID for metadata item 3861 (title: Dynasties) to com.plexapp.agents.none://cd3fa4409e7a9216278cc6593f9c40af615c5862?lang=xn (thumb: ) (instance rating key: )
Apr 01, 2020 00:35:59.578 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3861
Apr 01, 2020 00:35:59.580 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3861
Apr 01, 2020 00:35:59.581 [0x7ff6b3fff700] DEBUG - Refreshing metadata for 'Dynasties' (agent: com.plexapp.agents.none)
Apr 01, 2020 00:35:59.589 [0x7ff6b3fff700] DEBUG - Matching 'Dynasties' (ID 3862) with agent com.plexapp.agents.none
Apr 01, 2020 00:35:59.615 [0x7ff6b3fff700] DEBUG -  * Score: 100 (Dynasties)
Apr 01, 2020 00:35:59.615 [0x7ff6b3fff700] DEBUG - Setting GUID for metadata item 3862 (title: Dynasties) to com.plexapp.agents.none://1322d41585e075978ac058600d6b240a1e51683d?lang=xn (thumb: ) (instance rating key: )
Apr 01, 2020 00:35:59.617 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3862
Apr 01, 2020 00:35:59.619 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3862
Apr 01, 2020 00:35:59.620 [0x7ff6b3fff700] DEBUG - Refreshing metadata for 'Dynasties' (agent: com.plexapp.agents.none)
Apr 01, 2020 00:35:59.632 [0x7ff6b3fff700] DEBUG - Matching 'Dynasties' (ID 3863) with agent com.plexapp.agents.none
Apr 01, 2020 00:35:59.660 [0x7ff6b3fff700] DEBUG -  * Score: 100 (Dynasties)
Apr 01, 2020 00:35:59.660 [0x7ff6b3fff700] DEBUG - Setting GUID for metadata item 3863 (title: Dynasties) to com.plexapp.agents.none://209a7b6f69a404a9d5bcbda2b8f785ae2f8923a7?lang=xn (thumb: ) (instance rating key: )
Apr 01, 2020 00:35:59.663 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3863
Apr 01, 2020 00:35:59.665 [0x7ff6b3fff700] DEBUG - Updating metadata item (save) (Dynasties) with ID 3863
Apr 01, 2020 00:35:59.666 [0x7ff6b3fff700] DEBUG - Refreshing metadata for 'Dynasties' (agent: com.plexapp.agents.none)
Apr 01, 2020 00:35:59.674 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E02) with ID 3861
Apr 01, 2020 00:35:59.676 [0x7ff6b37fe700] DEBUG - [ID 7072] Media part analysis: /Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv
Apr 01, 2020 00:35:59.676 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:35:59.676 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:35:59.719 [0x7ff6b37fe700] DEBUG - [MI]  * cd3fa4409e7a9216278cc6593f9c40af615c5862 [mkv h264/dca] Duration: 3469483ms, 1920x1080 (1.777778) 25.000fps, bitrate=10822kbps, audio channels=6, optimizedForStreaming=0 ("/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv")
Apr 01, 2020 00:35:59.721 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E02) with ID 3861
Apr 01, 2020 00:35:59.722 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:35:59.724 [0x7ff6b37fe700] DEBUG - Updating part with ID=7072 [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv]
Apr 01, 2020 00:35:59.724 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:35:59.724 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:35:59.963 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:35:59.964 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:35:59.964 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:36:00.141 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.142 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.142 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:36:00.373 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.374 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.374 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:36:00.601 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.602 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.602 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv' for reading
Apr 01, 2020 00:36:00.787 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E02.mkv"
Apr 01, 2020 00:36:00.790 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E02) with ID 3861
Apr 01, 2020 00:36:00.794 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E02) with ID 3861
Apr 01, 2020 00:36:00.794 [0x7ff6b37fe700] DEBUG - Doing expensive tags write for 'Dynasties (2018) - S01E02' because something changed.
Apr 01, 2020 00:36:00.796 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E02) with ID 3861
Apr 01, 2020 00:36:00.799 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E03) with ID 3862
Apr 01, 2020 00:36:00.800 [0x7ff6b37fe700] DEBUG - [ID 7073] Media part analysis: /Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv
Apr 01, 2020 00:36:00.800 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:00.800 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:00.826 [0x7ff6b37fe700] DEBUG - [MI]  * 1322d41585e075978ac058600d6b240a1e51683d [mkv h264/dca] Duration: 3481760ms, 1920x1080 (1.777778) 25.000fps, bitrate=10781kbps, audio channels=6, optimizedForStreaming=0 ("/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv")
Apr 01, 2020 00:36:00.828 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E03) with ID 3862
Apr 01, 2020 00:36:00.828 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:00.829 [0x7ff6b37fe700] DEBUG - Updating part with ID=7073 [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv]
Apr 01, 2020 00:36:00.830 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:00.830 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:01.042 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.042 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.042 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:01.247 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.248 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.248 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:01.607 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.608 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.608 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:01.833 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.834 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:01.834 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv' for reading
Apr 01, 2020 00:36:02.047 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E03.mkv"
Apr 01, 2020 00:36:02.050 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E03) with ID 3862
Apr 01, 2020 00:36:02.054 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E03) with ID 3862
Apr 01, 2020 00:36:02.055 [0x7ff6b37fe700] DEBUG - Doing expensive tags write for 'Dynasties (2018) - S01E03' because something changed.
Apr 01, 2020 00:36:02.057 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E03) with ID 3862
Apr 01, 2020 00:36:02.058 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E04) with ID 3863
Apr 01, 2020 00:36:02.059 [0x7ff6b37fe700] DEBUG - [ID 7074] Media part analysis: /Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv
Apr 01, 2020 00:36:02.059 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.059 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:02.084 [0x7ff6b37fe700] DEBUG - [MI]  * 209a7b6f69a404a9d5bcbda2b8f785ae2f8923a7 [mkv h264/dca] Duration: 3492726ms, 1920x1080 (1.777778) 25.000fps, bitrate=10746kbps, audio channels=6, optimizedForStreaming=0 ("/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv")
Apr 01, 2020 00:36:02.086 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E04) with ID 3863
Apr 01, 2020 00:36:02.087 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.088 [0x7ff6b37fe700] DEBUG - Updating part with ID=7074 [/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv]
Apr 01, 2020 00:36:02.088 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.088 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:02.554 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.555 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.555 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:02.764 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.764 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:02.764 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:03.009 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:03.010 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:03.010 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:03.527 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:03.527 [0x7ff6b37fe700] DEBUG - [MI] Opening input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:03.527 [0x7ff6b37fe700] DEBUG - [FFMPEG] - Opening '/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv' for reading
Apr 01, 2020 00:36:03.737 [0x7ff6b37fe700] DEBUG - [MI] Closing input file: "/Pool01/Plex Media Library/Other Videos/Dynasties (2018)/Season 01/Dynasties (2018) - S01E04.mkv"
Apr 01, 2020 00:36:03.740 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E04) with ID 3863
Apr 01, 2020 00:36:03.744 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E04) with ID 3863
Apr 01, 2020 00:36:03.745 [0x7ff6b37fe700] DEBUG - Doing expensive tags write for 'Dynasties (2018) - S01E04' because something changed.
Apr 01, 2020 00:36:03.750 [0x7ff6b37fe700] DEBUG - Updating metadata item (save) (Dynasties (2018) - S01E04) with ID 3863
4.22 is the player version of the web app. Not the server version
I’m not a linux expert but have you confirmed permissions are the same as the other files
I’m also concerned with the “Because something changed” messages.
Did this occur while copying media into the directory or
is there another application writing into these files while PMS is trying to scan & match them?
It was a permissions issue, thank you!
see incorrect permissions on episodes 1 & 5:
I believe at one point I set this directory to always be read/write for all, but some files revert sometimes apparently… I don’t work with linux enough to have these things memorized, but I need to remind myself to do a ‘chmod -R’ every now and then
Regarding “Because Something changed” I did the scan immediately after copying so it’s possible the filesystem was still doing something with them
All good then.
Glad you got it.
