Library Folders no longer updating
Server Version#: 1.40.4.8679
Player Version#: N/A
New shows or episodes are not appearing in the library. I have checked the folders to ensure the files are there and playable outside of plex. Permissions on folders and files are also correct. A quick glance at the logs shows it tried to process some of those missing shows however I see no errors. This server has previously been working for over a year. Does not matter which player I use to connect to the server.
I would upload the full set of logs but it seems there is some personal information in some I’d rather not share. Let me know which files would be of most help from the log bundle and I will sanitize and post here.
Here is one of the deep analysis logs. It shows sealab 2021 episodes being analyzed but those are not showing up in any player. This is not the only affected show.
Jul 18, 2024 02:02:40.744 [140204195416832] INFO - Plex Media Scanner v1.40.4.8679-424562606 - Ubuntu PC x86_64 - build: linux-x86_64 - GMT 00:00
Jul 18, 2024 02:02:40.744 [140204195416832] INFO - Linux version: 20.04.4 LTS (Focal Fossa), language: en-US
Jul 18, 2024 02:02:40.744 [140204195416832] INFO - Processor: 12-core Intel(R) Xeon(R) CPU           X5675  @ 3.07GHz
Jul 18, 2024 02:02:40.744 [140204195416832] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze-deeply --item 10862 --log-file-suffix  Deep Analysis
Jul 18, 2024 02:02:40.746 [140204195933952] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Jul 18, 2024 02:02:40.861 [140204195933952] DEBUG - [MI] Opening input file: "/mnt/TV/Sealab 2021/Season 01/Sealab 2021 - S01E06 - Lost in Time WEBRip-1080p.mkv"
Jul 18, 2024 02:02:40.861 [140204195933952] DEBUG - [FFMPEG] - Opening '/mnt/TV/Sealab 2021/Season 01/Sealab 2021 - S01E06 - Lost in Time WEBRip-1080p.mkv' for reading
Jul 18, 2024 02:02:40.861 [140204195933952] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto,data'
Jul 18, 2024 02:02:40.862 [140204195933952] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Jul 18, 2024 02:02:40.862 [140204195933952] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Jul 18, 2024 02:02:40.862 [140204195933952] DEBUG - [FFMPEG] - st:1 removing common factor 1000000 from timebase
Jul 18, 2024 02:02:40.862 [140204195933952] DEBUG - [FFMPEG] - st:2 removing common factor 1000000 from timebase
Jul 18, 2024 02:02:40.862 [140204195933952] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 4045 bytes read:32768 seeks:0 nb_streams:3
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Decoding VPS
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Main profile bitstream
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Decoding SPS
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Decoding VUI
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Decoding PPS
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 39(SEI_PREFIX), nuh_layer_id: 0, temporal_id: 0
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - Decoding SEI
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - All info found
Jul 18, 2024 02:02:40.863 [140204195933952] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 7843 bytes read:32768 seeks:0 frames:5
Jul 18, 2024 02:02:40.950 [140204195933952] DEBUG - Deep Analysis: Read 10000 packets at 162.329000
Jul 18, 2024 02:02:41.004 [140204195933952] DEBUG - Deep Analysis: Read 20000 packets at 324.591000
Jul 18, 2024 02:02:41.044 [140204195933952] DEBUG - Deep Analysis: Read 30000 packets at 486.853000
Jul 18, 2024 02:02:41.086 [140204195933952] DEBUG - Deep Analysis: Read 40000 packets at 649.282000
Jul 18, 2024 02:02:41.090 [140204195933952] DEBUG - Deep Analysis: Sorting packets
Jul 18, 2024 02:02:41.091 [140204195933952] DEBUG - Deep Analysis: Performing file bitrate analysis
Jul 18, 2024 02:02:41.099 [140204195933952] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 0
Jul 18, 2024 02:02:41.102 [140204195933952] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 1
Jul 18, 2024 02:02:41.104 [140204195933952] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 2
Jul 18, 2024 02:02:41.104 [140204195933952] DEBUG - Deep Analysis: Saving GoP analysis for stream 0
Jul 18, 2024 02:02:41.105 [140204195933952] DEBUG - Deep Analysis: Saving bitrate analysis
Jul 18, 2024 02:02:41.105 [140204195933952] DEBUG - Updating part with ID=24936 [/mnt/TV/Sealab 2021/Season 01/Sealab 2021 - S01E06 - Lost in Time WEBRip-1080p.mkv]
Jul 18, 2024 02:02:41.106 [140204195933952] DEBUG - [MI] Closing input file: "/mnt/TV/Sealab 2021/Season 01/Sealab 2021 - S01E06 - Lost in Time WEBRip-1080p.mkv"
Jul 18, 2024 02:02:41.106 [140204195933952] DEBUG - Updating media item 24902, size=112663476, metadata_item_id=10862
Jul 18, 2024 02:02:41.106 [140204195933952] DEBUG - Updating part with ID=24936 [/mnt/TV/Sealab 2021/Season 01/Sealab 2021 - S01E06 - Lost in Time WEBRip-1080p.mkv]
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [MI] Opening input file: "/mnt/TV/Sealab 2020/Season 01/Sealab 2020 - S01E06 - The Basking Shark DVD.mkv"
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - Opening '/mnt/TV/Sealab 2020/Season 01/Sealab 2020 - S01E06 - The Basking Shark DVD.mkv' for reading
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto,data'
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - st:1 removing common factor 1000000 from timebase
Jul 18, 2024 02:02:41.107 [140204195933952] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 4655 bytes read:37691 seeks:2 nb_streams:2
Jul 18, 2024 02:02:41.108 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Jul 18, 2024 02:02:41.108 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Jul 18, 2024 02:02:41.110 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Jul 18, 2024 02:02:41.110 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Jul 18, 2024 02:02:41.110 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Jul 18, 2024 02:02:41.110 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Jul 18, 2024 02:02:41.110 [140204195933952] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Jul 18, 2024 02:02:41.111 [140204195933952] DEBUG - [FFMPEG] - no picture
Jul 18, 2024 02:02:41.112 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.112 [140204195933952] DEBUG - [FFMPEG] - no picture
Jul 18, 2024 02:02:41.113 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.115 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.116 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.118 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.122 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.126 [140204195933952] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Jul 18, 2024 02:02:41.131 [140204195933952] DEBUG - [FFMPEG] - All info found
Jul 18, 2024 02:02:41.131 [140204195933952] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 151431 bytes read:201957 seeks:2 frames:25
Jul 18, 2024 02:02:42.456 [140204195933952] DEBUG - Deep Analysis: Read 10000 packets at 130.112000
Jul 18, 2024 02:02:42.741 [140204195933952] DEBUG - Deep Analysis: Read 20000 packets at 260.245000
Jul 18, 2024 02:02:42.972 [140204195933952] DEBUG - Deep Analysis: Read 30000 packets at 390.400000
Jul 18, 2024 02:02:43.106 [140204195933952] DEBUG - Deep Analysis: Read 40000 packets at 520.512000
Jul 18, 2024 02:02:43.308 [140204195933952] DEBUG - Deep Analysis: Read 50000 packets at 650.645000
Jul 18, 2024 02:02:43.406 [140204195933952] DEBUG - Deep Analysis: Read 60000 packets at 780.778000
Jul 18, 2024 02:02:43.506 [140204195933952] DEBUG - Deep Analysis: Read 70000 packets at 910.912000
Jul 18, 2024 02:02:43.609 [140204195933952] DEBUG - Deep Analysis: Read 80000 packets at 1041.045000
Jul 18, 2024 02:02:43.708 [140204195933952] DEBUG - Deep Analysis: Read 90000 packets at 1171.178000
Jul 18, 2024 02:02:43.808 [140204195933952] DEBUG - Deep Analysis: Read 100000 packets at 1301.312000
Jul 18, 2024 02:02:43.829 [140204195933952] DEBUG - Deep Analysis: Sorting packets
Jul 18, 2024 02:02:43.834 [140204195933952] DEBUG - Deep Analysis: Performing file bitrate analysis
Jul 18, 2024 02:02:43.859 [140204195933952] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 0
Jul 18, 2024 02:02:43.870 [140204195933952] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 1
Jul 18, 2024 02:02:43.875 [140204195933952] DEBUG - Deep Analysis: Saving GoP analysis for stream 0
Jul 18, 2024 02:02:43.876 [140204195933952] DEBUG - Deep Analysis: Saving bitrate analysis
Jul 18, 2024 02:02:43.876 [140204195933952] DEBUG - Updating part with ID=24926 [/mnt/TV/Sealab 2020/Season 01/Sealab 2020 - S01E06 - The Basking Shark DVD.mkv]
Jul 18, 2024 02:02:43.877 [140204195933952] DEBUG - [MI] Closing input file: "/mnt/TV/Sealab 2020/Season 01/Sealab 2020 - S01E06 - The Basking Shark DVD.mkv"
Jul 18, 2024 02:02:43.878 [140204195933952] DEBUG - Updating media item 24892, size=408434167, metadata_item_id=10862
Jul 18, 2024 02:02:43.878 [140204195933952] DEBUG - Updating part with ID=24926 [/mnt/TV/Sealab 2020/Season 01/Sealab 2020 - S01E06 - The Basking Shark DVD.mkv]
I checked “Sealab 2021”.
There is a metadata retrieval problem.
Can you give me a list of specific entries to verify here so I can report them to the metadata team?
The other show is actually Sealab 2020.
There was another I thought wasn’t working but it seems fine now.
Thanks for the help.
Both confirmed missing and both reported to the metadata team
Doesn’t look missing to me: https://watch.plex.tv/show/sealab-2021
https://watch.plex.tv/show/sealab-2020
It seems to me that the files of Sealab 2021 and Sealab 2020 are getting conflated in your library.
Try adding their respective release year to the folder names.
Sealab 2021 (2000)
Sealab 2020 (1972)
Then perform the old Plex dance with both Shows.
Don’t forget to check the “Collections” tab of your library. Seemingly missing shows/movies might be simply lurking inside a collection.
I’d suggest adding the TMDB, TVDB, or IMdb IDs to the folder names as well. That’s cured a few ills with metadata confusion for me in the past.
I tried both naming the files with years and imdb ids. Did the plex dance both times. I didn’t notice a change adding just the year alone.
For anybody else who stumbles across this, this is the format I ultimately ended up with:
Sealab 2020 (1972) (tt0068129)
That format is not useful in Plex.
This is the correct syntax:
Sealab 2020 (1972) - {tvdb-70528}
