Truenas Scale Plex won't start if claim code is entered. Also cannot claim server without it
Server Version#: TrueNAS-SCALE-22.12.2
Player Version#: 1.32.1.6999_1.7.45 (offical)
Recently upgraded from truenas core to scale. Worked great on Core. Made a backup of entire server onto backup drive for safety. Getting set up and I am totally lost over the new options and i am struggling to find helpful videos showing all the details online.
My main issue as I see it:
install plex. have all the settings reasonable but the new Bluefin os changes the settings from anything i find online. i think i have the locations all set correctly for where to have “plex storage” options all working. but sometimes it’s stuck deploying. logs show this…
2023-05-11 19:50:12.808942+00:00[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
2023-05-11 19:50:13.169432+00:00[s6-init] ensuring user provided files have correct perms…exited 0.
2023-05-11 19:50:13.170057+00:00[fix-attrs.d] applying ownership & permissions fixes…
2023-05-11 19:50:13.170702+00:00[fix-attrs.d] done.
2023-05-11 19:50:13.171143+00:00[cont-init.d] executing container initialization scripts…
2023-05-11 19:50:13.171790+00:00[cont-init.d] 40-plex-first-run: executing…
2023-05-11 19:50:14.049054+00:00Attempting to obtain server token from claim token
2023-05-11 19:50:14.057514+00:00% Total % Received % Xferd Average Speed Time Time Time Current
2023-05-11 19:50:14.057596+00:00Dload Upload Total Spent Left Speed
2023-05-11 19:50:26.064678+00:000 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:02 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:03 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:04 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:05 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:06 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:07 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:08 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:09 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:10 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:11 --:–:-- 0curl: (6) Could not resolve host: plex.tv
2023-05-11 19:50:26.078367+00:00Plex Media Server first run setup complete
2023-05-11 19:50:26.079385+00:00[cont-init.d] 40-plex-first-run: exited 0.
2023-05-11 19:50:26.080829+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
2023-05-11 19:50:26.085392+00:00[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
2023-05-11 19:50:26.086320+00:00[cont-init.d] 50-plex-update: executing…
2023-05-11 19:50:38.134561+00:00Could not get update version
2023-05-11 19:50:38.135250+00:00[cont-init.d] 50-plex-update: exited 0.
2023-05-11 19:50:38.136364+00:00[cont-init.d] done.
2023-05-11 19:50:38.137586+00:00[services.d] starting services
2023-05-11 19:50:38.144246+00:00[services.d] done.
2023-05-11 19:50:38.145020+00:00Starting Plex Media Server.
2023-05-11 19:50:38.148969+00:00s6-applyuidgid: fatal: unable to exec /usr/lib/plexmediaserver/Plex Media Server: No such file or directory
2023-05-11 19:50:38.153352+00:00Stopping Plex Media Server.
2023-05-11 19:50:38.156603+00:00kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec … or kill -l [sigspec]
2023-05-11 19:50:43.167462+00:00Starting Plex Media Server.
2023-05-11 19:50:43.172023+00:00s6-applyuidgid: fatal: unable to exec /usr/lib/plexmediaserver/Plex Media Server: No such file or directory
2023-05-11 19:50:43.176545+00:00Stopping Plex Media Server.
So, i removed the “plex pass claim” option and it starts up. only error is
Critical: libusb_init failed
even so, plex boots but I cannot claim server
I suspect there’s more wrong with all this ( remote connection doesnt work but i suspect thats because the server isnt claimed) but I am barely able to stay afloat with all the new crap in Scale. Any and all help is appreciated <3
small update (still broken)
unchecked the plex pass button but still entered the claim code and plex runs. only log error is Critical: libusb_init failed
But I still cannot claim server…
thx
lsbinit failing isn’t critial. it just tells us the host doesn’t have the libraries installed.
This is the root (or a main) problem. DNS isn’t working.
You can’t claim it if it can’t talk to plex.tv
ok, good note! changed it to 1.1.1.1 for the sake of simplicity and now I have a new error I cannot seem to bypass.
Error: [EINVAL] chart_release_create.appVolumeMounts.data.hostPathEnabled.hostPath: Invalid mount ‘/mnt/WD Reds/Plex Media/All Media’ path. Following service(s) use this path: SMB Share
So, i moved all my media one folder deeper (all media) so as it was’t directly in the subfolder of the primary pool where my SMB is set to and still no luck. What am i doing wrong?
Can’t help there. I don’t know/use TrueNAS.
Maybe their forums?
yeah, you and me both haha. Unfortunately I cannot find much help for anything relating to their latest version os. and the GUI changed a lot so nothing is quite the same.
but I appreciate the pointers!
