Sorry for the length but this has been a major hassle so I’m trying to be thorough. I can’t find any information that relates to what I’m experiencing online anywhere. I tried the plex subreddit, but no one was able to help there. TL;DR at the bottom.
I have a massive library of ~15000 misc radio broadcasts and shows spanning several decades that I’m trying to add to my Plex server, and I have not had any luck with getting everything to show up in in a way that reflects the metadata or how I’ve organized the files. I’ve painstakingly gone through every file and set all the metadata tags by hand, setting album/artist to match the folder name and removing all other tags. The library either won’t update when I initiate a refresh or rescan, even when drilled down into the artist or album. I tried doing ‘refresh all metadata’ for the library itself but this didn’t update correctly either. Initially some of the tag changes I made DID register, but not for everything. A good portion of the albums still aren’t working correctly, or they have missing files or something else is incorrect.
Most of these don’t have any searchable online metadata information, but being hopeful, I initially I had left library settings at defaults to see if it would just pick up the folder names appropriately. This took 3 days and didn’t work, so I enabled ‘prefer local metadata’ which forces you to use the ‘Plex Music Scanner’ scanner. I set the agent to ‘Personal Media Artists’, and tried toggling everything else on or off at different times, but no permutation of this will make the files update to their configured metadata.
In the top-level folder I have everything grouped in 1 layer of subfolders based on people, or shows. For example, Amos & Andy, which has 224 mp3s. I set all these IDv3 tags for Album and Artist to “Amos & Andy”, and removed everything else. My intention is to play the files alphabetically as the dates are nested inside the filename. Ideally when I go to my library, I should see “Amos & Andy” with all the files showing up in the correct order, in one playlist. I don’t mind if it’s another click if I can’t omit the requirement for having a separate “artist” and “album”, but ideally everything should show in one playlist as shows sometimes span multiple segments/files.
What happens is all over the place usually. For this example, 2 albums show up: one album still has album art with 4 files in it, the other album doesn’t art and has 218 files. 2 files are missing from the artist. When doing a global search, they show up in a 3rd artist, “BBC - The Real Amos & Andy” but with the correctly tagged album of “Amos & Andy”. These should all be part of the same radio series, so they should never be splitting up like this. It’s like the local metadata scanner just gave up partway through, and it’s retaining whatever original data it managed to scrape online or whatever it has cached from the initial tags. Other artists show up similarly wonky. Some have each file as a separate album and each album is named the same thing, some have artists or albums that I have no idea where they came from, some have old metadata, but some are correct.
Sorry for the lengthy description but this has been several days’ worth of work, and I’ve done a lot of preliminary testing. I’m assuming whatever was used for encoding has restrictions, like a particular version of LAME or similar, and whenever I try to refresh it doesn’t capture the changes. Or, the local scanning agent just isn’t working at all. These are all MP3s but the bitrates and such are all over the place. I verified file/folder permissions are all set correctly, also.
Thank you for reading. Let me know if anyone has any suggestions.
TL;DR Can’t get 15000 MP3s to show up in Plex and it doesn’t seem to be reading the metadata correctly for all of them despite having the prefer local metadata switch enabled. Refreshing library, artist, or album doesn’t work. Albums and artists are split up in ways that don’t match the tags.
