turnoff auto play in TV Shows
Recenty autoplay has started with plex, it will play a new episode without being asked, how do i turn off that feature.
It only autoplays if you pick it from On Deck. Solution = don’t pick it from on deck.
That is not a solution and I am not even sure it is true for all clients.
All the clients I use (Roku, Fire TV, Shield and PMP on a Raspberry PI) have a way to turn off auto play in the respective settings menu. Just access the settings menu and look around and you will find, probably, a way to turn it off.
PMP has never had an option to turn off autoplay. I just checked.
You are correct. I was working from memory and I have not been using my PI since I received my shield so my old memory was/is faulty.
However, to be sure, I checked on my Roku (Which is what I use 90% of the time), my Fire TV and my Shield and they all have the ability to turn that intrusive function off. They call it ‘Play “Up Next” video automatically.’ Except for the Roku that calls it “Post Play Auto Play.”
I guess the PMP team is lagging some in their development efforts.
Sorry for the mistake about PMP.
That’s ok we all make mistakes. They are clearly trying to aim for platform uniformity as the Android TV client just got this feature and you can turn it off and on. Probably best to create a feature request for this.
