Please help me. Few days ago I was streaming my video .avi from my plex server to my tizen samsung, home network.
It didn’t work, black screen. Probably because the .avi format is too old.
But if i’ll buy the lifetime pass, something will change? With the hardware transcoding something will change? Or i have to convertire my file into .mkw?
I don’t think a plex pass will help with that. Converting the file to a newer format like mp4 will probably do the trick. I don’t know if you have a program to do it. Handrake can do it as well as ffmpeg
If the file isn’t playing there is likely a Plex issue here. If a client device cannot play a file directly then PMS is supposed to transcode it. That’s the entire point of Plex.
You should post the media info here at least, if not a sample file. AVI is just a container format. It does not tell us what the audio and video are you cannot play.
This happened to me after my most recent update. I found reference to it online, though I don’t recall where. All my older .avi files stopped being viewable on my Plex server. There weren’t many, so I just converted them to .mp4 and all was well.
That doesn’t tell what you actually did with the file. VLC can copy component streams or transcode them to other formats as directed by the user. One method results in quality loss to the media, the other does not.
If you create a new Convert profile you’ll see you have options on what to do with the video, audio, etc. I would be make sure to test anything you make with it. I tend to get wonky mkv files out of it quite often that won’t seek properly for example.
