New to Plex. I am starting to load some TV shows. I have followed the Plex naming convention, but I cannot get the episode names to show on the server.
now as for your problem…
as stated above… the naming is basically fine; Plex properly determined the show name and season/episode numbers. you might run in to a problem with matching… but the problem at hand is that Plex fails to even attempt to match the show.
these days lots of people have trouble getting the metadata from TheTVDB.com. sadly there appear to be only 2 modes to fix it:
Something else that just dawned on me. If Plex’s displaying of the episode names is related to TVDB’s matching, then my adding the episode name to the file name has nothing to seeing the name on Plex. I could have just had, “Kidnapped - s01e02” rather than “Kidnapped - s01e02 - Special Delivery” and I would have gotten the same results?
From my experience, if the episode has never been matched, Plex will keep retrying (not sure how often, might be just when it scans the library), until it eventually matches and downloads the data
I have daily episodes which occasionally are not on tvdb, and within a day or so of the episode being added to tvdb, Plex retrieves the details without me doing anything
Once downloaded they should stay, even if tvdb goes offline
that’s correct.
those extra information in the file name are only useful if you access the file differently or search the file system for a certain title.
