TV Grid not matching EPG data
Server Version#: 1.25.8.5663
Player Version#: Plex Web—General 4.77.3
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name: n/a
Hello,
I’m seeing an odd issue where the underlying EPG info is correct, but it’s not showing up properly in the guide. It happens only on Sundays when 4:30pm is showing in the grid. In the screenshot below you can see that every single show on at 4:30pm gets repeated at the 5:00pm slot even though if you click on a show it will show whether it’s actually playing. If I slide the guide over such that 4:30pm is not showing then the guide is properly updated. Doesn’t seem to happen on other days, but it appears on all future Sundays, also only when 4:30pm is showing.
Here you see the repeated information:
Here is the correct information once I scroll past showing 4:30pm on the screen:
I’ve updated to the latest version and refreshed the guide. Anything else to try before deleting and recreating the DVR?
I recently noticed something similar. The second Young Sheldon Episode gets listed twice on my guide and the shows after it are pushed out a half hour. It seems to be recording correctly and seems to just be a display issue. I don’t know when it started but it’s fairly recent or I’d have noticed it before.
Another example. The Rockford Files airs at 6pm mt on GetTV and records correctly. However, the second Kojak is repeated on the guide display and The Rockford Files entry is incorrectly pushed out to 7pm mt.
