TV Guide Format
I have noticed the format in the TV Guide is showing date and episodes on the Plex server but on the ATV is fine showing the times, is this a bug? also, the date format show be DD/MM/YYYY and not MM/DD/YYYY
Does the Apple TV Time format been set up correctly?
I see your in NZ, your official date format is DD/MM/YYYY
The ATV looks perfectly fine it is the format showing in the TV Guide in Plex on the PC, all regional formats etc are set correctly!!
I guess, if I can’t fix it now one else can!!
The issue is Language sets the date format, if there was a NZ and or AU English available this could be corrected.
Thanks for that, I changed from English to English (UK) and that fixed it, I would have never of thought of that!!
Sorry. deleted your reply by mistake
Glad that solved your issue
