TV Guide search is case sensitive
Search2
I still have problems with TV Guide search, and one of them seems to be the search is case sensitive, see attached screenshots for an example
Server Version#: 1.22.0.4163
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Interesting. It only seems to be an issue for “Live TV”…
Screenshot 2021-03-15 at 17.45.28
did again and got this - bizarre.
Screenshot 2021-03-15 at 17.46.43
This might not be an issue anymore, after the 1.22.1 server upgrade.
Are you using a XMLTV file or the Plex-provided EPG?
I don’t see this issue. BUT, the issue that remains is search results aren’t returned on the first try.
1st try
2nd try
Any idea when this will be fixed?
I am on PMS 1.22.0 and using the Plex EPG.
I don’t think this is an issue of the search being case sensitive, but the following issue that has been an issue for quite some time:
No, I’m using the Plex Provided EPG.
Now on version 1.22.1.4228 and it is still a problem
Try cutting out the search term and pasting it back – unmodified.
Do you then also get a result?
Yes, after cutting, then pasting the same search term gives results
So it is indeed the same issue as @Noah0504 above has linked.
Have you updated to PMS 1.22.2 yet?
There is one bugfix in it which sounds like it is related
I am running 1.22.1.4228 and can confirm the bug is still present.
Edit: Wait, 1.22.2 or 1.22.1? I just happened to look at the version number of the announcement you linked to, but that’s not the version number your actual comment mentions.
Edit: I see the 1.22.2 beta was just released. :slight_smile: I’ll update in a little bit and see if that fixes it.
…and it does.
@TheDukeofPrunes, updating to the new PMS beta fixes the issue.
