TV Show Editions Release
Today we’re opening up Editions for TV Shows to Plex Pass subscribers.
If you’ve ever had both a dubbed and original-language version of an anime show in your library, or The Wire in 4:3 and the remastered 16:9, you know the awkwardness: they’re the same show, but they’re not, and Plex had no clean way to treat them as two distinct things.
You may already be familiar with Editions from movies. Same idea: when you have two genuinely different releases of a TV show (not just different quality encodes of the same content) you can label them as separate editions. Each gets its own listing in your library, tracked independently for watch status, ratings, and metadata.
Some examples of where this comes in handy:
  • Dubbed vs. original-language releases (anime fans, you know who you are)
  • Color and black-and-white editions of the same series
  • Shows re-released in a different aspect ratio (The Wire 4:3 vs 16:9)
  • Remastered versions worth keeping separate (Babylon 5: Blu-ray Remaster)
  • Multiple episode orders for the same show
Setting it up:
Two options — use whichever fits your workflow:
  1. Append {edition-Name} to your show’s top-level folder: /TV Shows/Babylon 5 (1994) {edition-Bluray Remaster}
    Note: If you’re renaming an existing folder, Plex will treat it as a new library item and prior watch history won’t carry over. Use the Edit method below to avoid that.
  2. Edit the library item: Open a show in Plex Web → Edit → fill in the Edition field. This preserves your existing watch history and metadata.
Pro tip: Editions show up as separate entries in your library grid, so it’s worth giving each one a distinct poster to make them easy to tell apart.
A few things to keep in mind:
  • Requires a Plex Pass subscription to add or edit edition info
  • Watch status and ratings are tracked per edition, there’s no cross-edition syncing
  • Editions are defined at the show level, not per-season or per-episode
Client support:
Recommended to have at least version 1.43.3 of Plex Media Server
Edition display is live now in Plex Web (4.160) and rolling out in the iOS and Android apps (version 2026.13.0). Roku support is coming in the next release.
In clients that do not support the feature yet, the edition information will not appear but they will be separate listings. It is recommended to select different show posters to tell them apart.
Known issues:
Edition titles may not display correctly in grid view when filtering by Seasons or Episodes. A fix is on the way.
We’ll update this thread as Roku and other platforms roll out.
If you have any bugs/issues to report about the current implementation please tag any topics you create with the edition tag
