I’ve got a semi-large library, and I’m in the process of attempting to sort my shows by station they aired on, and then the show, then the season however Plex seems to be merging shows into one. Is it possible to have Plex properly read something like:
TV/Station/Show/Season/Episode/Episode file.ext or do I need to keep it as TV/Show/Season/Episode/Episode file.ext? I checked the FAQ but it didn’t exactly specify what I was looking for.
This is the specified format for plex (https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows):
/TV Shows <--- With the library pointing here
/Grey's Anatomy
/Season 01
Grey's Anatomy - s01e01.avi
Grey's Anatomy - s01e02 - The First Cut is the Deepest.avi
Grey's Anatomy - s01e03.mp4
/Season 02
Grey's Anatomy - s02e01.avi
Grey's Anatomy - s02e02.mkv
Grey's Anatomy - s02e03.m4v
With that being said, if you add your subfolder it would look similar to the following with just pointing the library at a different folder:
/TV Shows
/Random Studio <--- Library Points here
/Grey's Anatomy
/Season 01
/Random Other Studio <--- Library also points here
/Dark Matter
/Season 01
Dark Matter - s01e01 - Episode One.avi
If you do your setup and point to TV Shows you are telling Plex that your studio sub folders are the actual tv show names. This is why you will need to point the TV Show library to each individual studio folder. I separate my TV Shows into sub folders so my library itself looks like this:
I was afraid of that. Thanks.
