I am new to plex and have a question on organizing tv shows and movies. My tv shows appear under both the Movies library and the TV Shows library. Is there a way to fix this so that they only appear in the TV Shows library?
Thanks,
John
Thanks,
John
I’m going to go out on a limb here and say that if you edit your Movies library and look under “Add Folders”, you’ll find the folder your TV Shows are in listed. Delete it and make sure that your TV Shows and Movies are in seperate folders.
You cannot have TV shows and movies in the same library and they need to be in completely separate directories and you MUST name them according to Plex standards.
For TV shows follow the following exactly:
TV Shows <— The library points here
---------TV Show Name (Year first aired if needed) <— This folder holds the season folders
------------------Season 01 <— This folder holds all the episodes for season 01
-------------------------ShowName - s01e01 - Episode Name.ext
-------------------------ShowName - s01e02 - Episode Name.ext
-------------------------And so on for the rest of season 01
------------------Season 02 <— This folder holds all the episodes for season 02
-------------------------ShowName - s02e01 - Episode Name.ext
-------------------------ShowName - s02e02 - Episode Name.ext
-------------------------And so on for the rest of season 02
------------------Season 03 <— This folder holds all the episodes for season 03
-------------------------ShowName - s03e01 - Episode Name.ext
-------------------------ShowName - s03e02 - Episode Name.ext
-------------------------And so on for the rest of season 03
---------2nd TV Show Name (Year first aired if needed) <— This folder holds the season folders
-------------------------2nd ShowName - s01e01 - Episode Name.ext
-------------------------2nd ShowName - s01e02 - Episode Name.ext
-------------------------2nd ShowName - s02e01 - Episode Name.ext
-------------------------2nd ShowName - s02e02 - Episode Name.ext
-------------------------2nd ShowName - s03e01 - Episode Name.ext
-------------------------2nd ShowName - s03e02 - Episode Name.ext
Note: The year after the show name is only normally needed or desired if there is more that one show with exactly the same name. Check http://thetvdb.com/ if you are not sure and match exactly the name used there. There are some exceptions to this where the year is needed even if there is no other show of that name or if the show does not have the year in TheTVDB.
There are naming methods other than the above that work but this does work 99.9% of the time.
If you are going to use Plex it is best to use the proper naming conventions so Plex makes the best match possible. Trying to force Plex to use other naming methods is just asking for frustration.
https://plexapp.zendesk.com/hc/en-us/articles/200220687-Naming-Series-Based-TV-Shows
Movies are a bit more flexible and you can have nested directories with many movies in a single directory or a separate directory for each movie.
https://support.plex.tv/hc/en-us/articles/200381023-Naming-Movie-files
The separate directory for each movie is needed if you want to take advantage of many of the fluff features that Plex offers.
