Server Version#: 1.40.0.7775
Player Version#: Multiple Clients
If I enable either Recently Released Episodes or Recently Added TV it will break the Recommended Tab on that library on all Clients except Plex Web.
If I remove both those than the tab will load just fine. I have tried using Chucks DBRepair script with no luck.
tom80H
January 30, 2024, 6:21pm
2
How so?
Any error messages other symptoms?
Nothing in logs, even after debug log enable. It does list the hub url it tries to hit, i will see manually what that brings up… Visually this is what happens… the reload is after i enable recent tv…
Manually hitting that endpoint results in this:
So it seems like it was this TV Show…
<Video ratingKey="791563" key="/library/metadata/791563" parentRatingKey="791213" grandparentRatingKey="750943" guid="plex://episode/6597444fdb3793e7d8f13530" parentGuid="plex://season/6597444edb3793e7d8f1351f" grandparentGuid="plex://show/5d9c08692192ba001f30f7ca" grandparentSlug="8-out-of-10-cats-does-countdown" type="episode" title="Rob Brydon, Katherine Parkinson, Jon Richardson, Babatunde Aléshé" titleSort="Rob Brydon, Katherine Parkinson, Jon Richardson, Babatunde Aleshe" grandparentKey="/library/metadata/750943" parentKey="/library/metadata/791213" librarySectionTitle="TV Shows" librarySectionID="5" librarySectionKey="/library/sections/5" grandparentTitle="8 Out of 10 Cats Does Countdown" parentTitle="Season 25" contentRating="TV-MA" index="3" parentIndex="25" year="2024" thumb="/library/metadata/791563/thumb/1706521402" art="/library/metadata/750943/art/1706521442" grandparentThumb="/library/metadata/750943/thumb/1706521442" grandparentArt="/library/metadata/750943/art/1706521442" grandparentTheme="/library/metadata/750943/theme/1706521442" duration="2849840" originallyAvailableAt="2024-01-26" addedAt="1706311005" updatedAt="1706521402" chapterSource":"media","pv:chapterImagesStale":"1","url":"ma:chapterSource="media">
<Media id="2061545" duration="2849840" bitrate="5119" width="1920" height="1080" aspectRatio="1.78" audioChannels="2" audioCodec="aac" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="PAL" audioProfile="lc" videoProfile="high">
<Part id="2122598" key="/library/parts/2122598/1706416800/file.mkv" duration="2849840" file="/data/TV/8 Out of 10 Cats Does Countdown (2013)/Season 25/8 Out of 10 Cats Does Countdown - S25E03 - Rob Brydon, Katherine Parkinson, Jon Ricardson and Babatunde Aléshé WEBDL-1080p.mkv" size="1823577506" audioProfile="lc" container="mkv" videoProfile="high" />
</Media>
<Role tag="Jimmy Carr" />
<Role tag="Jon Richardson" />
<Role tag="Rachel Riley" />
</Video>
I deleted it and now its fine lol
