Is there anyway to display the status of a TV show? By that I mean if it is still running or if the show has ended
On my server I have Sick Beard and the webpage to view it has the continuing/ended status. Likewise you can use tvdb.com to check that status as well, these are other work around choices for you.
It does't look like the plex plugin that pulls in info from thetvdb.com harvests that bit of info.
And I moved you question to the Metadata agent forum...
OK thanks for confirming, is this something I need to request as a new feature?
i would like that feature to
