Server Version#: 1.16.5.1488
Player Version#: Latest
Watching Season 1 (S1) from show A works great. Finish last episode of S1.
Start Season 2 (S2) from show A doesnt work.
Shows message about checking connection to server.
Same issue with several shows. Finish S1 and want to continue to S2.
And all seasons behind the one that was working stops working.
Server located on same gigabit network with cat6 cables.
Shows work in browser as they should.
Other shows/movies work so there isn’t a connection issue from TV.
Files are located on disk where they should be.
Tried the following:
Restarting server.
Cleaning and repairing database.
Clearing app cache etc on TV.
Reinstalling app on TV.
Changed settings to allow unsecure connection on local network.
Workaround:
Removing the files from disc and copying them back to the same place and updating the library makes it work for one more season. But then when S2 is done it breaks on S3 and same thing has to be done.
Problem seems to have showed itself after the latest update for the app with new GUI.
Any tips on what can be done?
