TV Shows theme song not Playing
Hi All!
Recently i have update one of my tv shows in the plex folder. After this update the theme song of the show stop to play. Other shows are playying normally.
Running in Unraid 6.12.1 as docker
Server Version#: 1.32.5.7210
Player Version#: All
Plex Media Server Logs_2023-06-24_19-03-34.zip (4.8 MB)
I thank you in advance for any help!
Braz.
Hi All!
Just an information.
I have rollback the version to 1.32.4.7164 and the theme music is playing fine.
I’m on TrueNAS Scale also using a Docker container for PMS.
I am on Version 1.32.5.7318. This was recently set up so I don’t have an easy option for rollback.
On previous PMS that I was running on other machines I had no issues with Theme Songs at all.
On my new server, there are no Theme Songs being pulled down at all while using the new Plex Series Scanner. All other settings appear to be correct.
I’m only able to get the shows to get a Theme Song if I change my MetaData agent to The TVDB and then going through each show and doing a ‘Fix Match’ again.
If I change the MetaData agent back to Plex Series Scanner and run Fix Match again, the Theme Song is then lost.
If I go back to my Windows Laptop with a Plex Media Server instance running Version 1.32.4.7195 (Up to date according to it) and add a random TV Series from a hard drive, the show instantly picks up the Theme song. Using Plex TV Series Scanner and Agent
