TV subcatagories
I don’t like having all my TV shows appear in one page. Is there a way to create categories so that instead of each TV show, it will display the categories “cartoons”, “Sci-Fi”, “Sit-Coms”, etc. Then when I select those, it will show all the shows of that category.
Sure…
Create more TV Show Libraries.
I have 4 ATM - to go along with those 22 Movie Libraries.
You probably won’t need 26 Libraries - unless you do.
Create a few playlists and see how that works!
It’s simple and works pretty well.
The user can pick the option that suits…
… but if either of those two suggestions above is easier to set up and use than just making a few more libraries - I’ll kiss every ass on Bear Creek Road (known locally as the area with the nastiest asssess in the county)…
lol
@trumpy81 said:
Start kissin’ then JuiceWSA … lol
You don’t have to name or organise anything or move anything.
Just go into your TV Show library, which you have already named and organised and Shift/click or CTRL/click on any TV Shows you want to add to a collection and edit the collection tag.
It doesn’t get any simplier than that. :tongue:
Season Greetings BTW :slight_smile:
I tried setting up a Collection once… then I tried to remove it… it was then I swore to never drive down that road again.
Happy, Happy, Merry, Merry…
B)
I have so many Libraries now it just doesn’t matter any more - but it do make it easy to move stuff to new HDDs when they show up and since I have More Libraries with Less Stuff in each, my eyeballs don’t bleed when I have to look at one of them in these horrific apps and the access speed is almost instantaneous:
B)
Thanks. I had not thought about making them all libraries. I’m used to the libraries just being Movies, TV Shows, and Music. I’ll go with your suggestion
