Any channel just fails… I can’t figure it out…
Working fine on any other software and even using nextpvr remotely works fine.
Plex… won’t work locally or remotely for live tv.
TV guide is also NOT showing on Samsung TV Plex app… which is annoying…
Dual win tuner being used. Scanned fine. Use to work. Now never does. Nothing has changed other than Plex server being updated.
Paying customer so quite keen on having this fixed…
(Sorry think posted in wrong area… forums are very confusing to use on phone)
Have you tried deleting the DVR and re-adding?
Are there other things you have tried? (Posting those will keep folks from recommending things you’ve already done.)
Please post the PMS version installed (exact number, not just “latest”) and OS it is installed on.
You can add PMS logs to your post as well:
Make sure DEBUG is ON (default setting) and VERBOSE is OFF (default setting) in Settings / Server / General, then repeat the issues, wait a few minutes, shutdown PMS, then restart and wait 6-7 minutes for the server to settle, Finally download the logs from your server and post the zip file.
Thanks for the quick reply.
I have tried removing DVR, it did help for a short while and now its back to where we area.
Plex running on Windows 10, Plex server Version 4.18.1
Just trying now, sometimes some channels may work, but then it will not at all.
here is the log from the console from just trying to tune into BBC 1
log.txt (66.2 KB)
