TVDB isn't matching my show correctly
Didn’t know where to post this, but for the show “One Piece”, TVDB lists the special episode “One Piece: Heart of Gold” as Special #35.
I’ve created a Season 0 folder, and have tried many names to see if Plex would find a match, but no luck. Here are some of the names I’ve tried:
One Piece - 00x35 - One Piece Heart of Gold
One Piece - 00x35 - Heart of Gold
One Piece - Special 35 - One Piece Heart of Gold —> (This was how FileBot named it)
One Piece - 00x35
00x35
No luck. How do people usually organize anime specials and OVAs? I’ve read through similar forum posts to try and help, but no luck :frowning:
Try: One Piece - S00E35 - One Piece Heart of Gold
Ref: https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
You have to tell Filebot that you are using Plex, and not Kodi.
I’m using FileBot 4.8.5, but I’ve always used it to search TVDB for the names of episodes and then click the rename button. How would I add the {plex} binding?
Sorry, no luck. Didn’t seem to work with your suggestion either.
Just click on the ‘Match’ button before you add any files to rename.
Then click on ‘Edit Format’
For the rest please use the Filebot FAQ
https://www.filebot.net/forums/viewtopic.php?f=3&t=7
What’s the agent’s used, since listed as episode 32 on themoviedb.org
And episode 35 on thetvdb.com
https://www.thetvdb.com/series/one-piece/episodes/5687281
Thanks for the quick reply. I listed TVDB as my main agent.
Then do @OttoKerner 's Plex Dance, followed by uploading a zip with the logs
Okay, I used your filebot method and it ended up working. Thank you and Dane22 for getting back to me so quickly. If I have anymore questions I’ll be sure to post here again!
