TVDB Regional Listings
Plex does not appear to have an option to select which listings to use when a show has multiple “regional” listings.
For example: https://thetvdb.com/series/scotts-vacation-house-rules if you look on the right hand side, there is an option to select between USA and Canada… The episodes had a different order and airdates on HGTV and HGTV Canada.
Is there any way to tell Plex to use the USA listings rather than the Canadian so the metadata matches the actual recordings?
