TVMAZE agent?
I was wondering if someone could create an agent for TVMaze? Since TVRage has been offline almost a month. None of my WWE shows are being updated. thetvdb doesn’t have any thing updated for Monday Night Raw since 2012. Not sure but there is an tvmaze.api out but not sure if that will work for Plex, but if someone could release an agent… I would be most grateful! :smiley:
https://www.themoviedb.org/search?query=wwe
The moviedb manages both movies and series now, and it seems WWE Raw is the monday night show [themoviedb.org/tv/4656-wwe-raw]
Can you confirm that it is the same show and if themoviedb agent for series does work ?
Awesome thanks ZeroQI… didn’t know they did tv shows since i only use them through plex and a filebot for movies and used TVRage for tv shows. Ever went to the site. Looks like they have most. Maybe I can add the WWE little shows from WWE Network there manually then.
Thanks Again!
I tried using the moviedb, and it renamed nothing in filebot…
Filebot tmdb episode info not yet supported in filebot acccording https://www.filebot.net/forums/viewtopic.php?f=6&t=2075
