[ALPHA] Wrestling Metadata Agent
I don't know if I'm the only one, but I'm really frustrated by TheTVDB's lack of support (and what sometimes seems like outright contempt) for pro wrestling. However, TVRage has no such issues (it's what I use in Filebot for renaming purposes). So I wrote this agent that pulls metadata from TVRage.
It also pulls artwork for a few shows from TVDB, but I had to hard-code the IDs for those because with the awful state of wrestling shows on TVDB I couldn't find an easy, reliable way to match the shows with the right IDs. They are Raw, SmackDown, Impact, WWE Pay-Per-View, NXT, Tough Enough, and Nitro. I couldn't find any other ones on there with useable cover art, anyway.
This is my first time writing anything in Python, and I'm still getting used to it and the Plex Framework, so I'm labeling this an alpha release. There are probably bugs and quirks, and I'm still looking for a better way ti get artwork. Any suggestions and comments would be much appreciated. If you try to use this and it doesn't work for you or there's some sort of bug, please give as much detail as possible and post the log (preferably pastebin).
Enjoy!
P.S.This should work reasonably well as a general agent, except for artwork, if you want to use TVRage data instead of TVDB. But again, it's an alpha release, so proceed with caution.
Wrestling.bundle.zip (91.4 KB)
OMFG THANK YOU! This has been long over due I'll download and give it a try and report back.
EDIT: The agent does not seem to add any info the season, episode and show numbers are correct.
No info? I'm not sure what you mean. Can you post a screenshot?
Have you set the shows to be matched by the Wrestling agent?
Here are some screenshots of how I have my files organised and the agent I am using.
As you can see in the bottom screen shot no info is displayed.
Everything looks right... Can you post the logs for the plugin? They should be in the PMG Plug-In Logs folder as com.plexapp.agents.wrestling.log, com.plexapp.agents.wrestling.log.1, etc. Hopefully that'll shed some light on what's happening. It looks like it downloaded the artwork, right? So it should have grabbed everything else too, as that's the last thing it does.
Here is the log for the plugin.
OK, I think I fixed it. Here's a version with a fix. I suggest clearing all the data in your WWE section before running it again, because it seems like there's a problem parsing the data that was already written. Let me know if it works!
Just updated the agent. Changes:
  • Show and episodes summary fields are now populated
  • Added setting to clear the plugin's HTTP cache on refresh. This can be used to get proper metadata in case the TVRage database was experiencing issues when the agent last ran. This should be used sparingly, and the chache itself only lasts for a day, so this is mostly for those who are impatient (like me). I recommend disabling this option once the proper metadata is downloaded.
As always, any feedback is greatly appreciated!
A++  Your selling your self short.  You should be marketing this as a TVrage metadata replacement.  I have several shows with which I'm not thrilled at the TVDB ordering or maintenance.  This fixed that problem.  Pulled the Data from TVrage and fixed several shows.  Thanks!
Thank you akkifokkusu.
Having thought that I could simply add WWE as a TV show and then finding out that I could not, I am grateful you created this plug in, so that my son can also use plex with his favourite WWE episodes.
Worked perfectly.
Thanks again!
AWESOME plug-in. As has been mentioned before, this really should be renamed to TVRageAgent or something. I just used it to fix the ordering of American Dad! For some reason, the episode info didn't populate until I went into the web interface and clicked on each episode. Once I did that and went back out to the Season, all the episode names were properly populated and all of the summary info was there as well. Since I've told Plex to use this agent for American Dad! can I assume that all future episodes will also be scanned using this instead of TheTVDB.com agent?
Thx!!
AWESOME plug-in. As has been mentioned before, this really should be renamed to TVRageAgent or something. I just used it to fix the ordering of American Dad! For some reason, the episode info didn’t populate until I went into the web interface and clicked on each episode. Once I did that and went back out to the Season, all the episode names were properly populated and all of the summary info was there as well. Since I’ve told Plex to use this agent for American Dad! can I assume that all future episodes will also be scanned using this instead of TheTVDB.com agent?
Thx!!
Thanks so much for the great feedback. I probably will offer it as a TVRage plugin soon, just need to get rid of some of the extra stuff that’s in there just for wrestling.
As far as the info not populating right away after switching agents, I’ve seen the same thing and I think it has to do with the way Plex handles its cache. It’s definitely frustrating for when I’m testing, but seems to work fine once everything is set up.
And yes, it should use TVRage for all future episodes of any show you set it for.
Sent from my Nexus 5 using Tapatalk
I am having problems getting the agent to work properly for WWE Pay-Per-Views. I have have my WrestleManias and SummerSlam events ripped and named according to how they are listed on TVRage. I have Plex scan my Wrestling folder, but none of the metadata is coming in properly.  All of my seasons are show "Episode 1", "Episode 3", etc. instead of the event name and none of the description data is coming in.  Any idea what I may be doing wrong or how to get this data to show properly?  I have tried doing a deep scan after the initial scan and no new information comes in.
Thanks.
Thanks.
I haven't had too much trouble with PPVs (though I think I sometimes had to rename the files manually first). Can you post the logs for the plugin after scanning? They should be in the PMG Plug-In Logs folder as com.plexapp.agents.wrestling.log, com.plexapp.agents.wrestling.log.1, etc.
As long as the WWE PPV's are added as a 'movies' library, it will get all of all of its metadata from themoviedb.org: http://i.imgur.com/WXfBjMi.png
Cheers
Here are the logs.
Here are the logs.
OK, I think I found the problem. This should fix it.
Sweet!  Thanks for the quick reply and fix. I removed and readded my videos and rescanned. Everything looks like it is pulling correctly now.
No problem, I'm glad that did the trick.
I'm getting an Exception trying to import the metadata from one of my episodes. Can you take a look?
It looks like an issue with date parsing. On tvrage, the episode doesn't have a complete date and is listed as 00//2002. The agent should handle this and either skip the date or just add the year.
