Two separate movies on one title
Can someone help… I have two separate movies in one title…like the movie THE FAN is in THE KARATE KID… how can I separate them… thanks
  1. https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
  2. https://support.plex.tv/articles/201019537-rename-a-badly-named-file/
  3. https://support.plex.tv/articles/201018248-merge-or-split-items/
click the 3 dots on the movie, choose split apart, and then go into the one that is labeled wrong and click the 3 dots, and choose fix match. Find the movie it is supposed to be, choose it, boom.
Ok that merge or split worked for one of my movies but as for the karate kid… it separated them but it did play THE FAN…
That’s why I listed 2 other articles first.
Name your files correctly, then you can avoid these issues.
After renaming a file that has been misrecognized, perform the Plex Dance
I did that in my external harddrive drive but nothing…
You did what exactly?
After renaming the files correctly on the hardrive, move one of them out of the folder - scan the library in Plex and match the movie if nessesary- then put the the other movie back in the folder and do another scan. Should help
I renamed the movie in my Library and then went to karate kid in Plex then split movie… once I did that two karate kids came up so I checked for the one that was THE FAN movie and tried to play it but wouldn’t play… I’m going to start over… I’m going to delete THE FAN movie and start fresh…
Perform the Plex Dance
In exactly the noted order and all steps.
Ok I got in Plex now… thank you
