two tuner (x2)/channel selection question
So let’s say you have two tuning devices (like a WinTV and a HDHomerun). Could you limit which channels get recorded via which device?
Just as an example, let’s say you have 4 channels available, 3/5/8/13. You want 3 & 5 to record via the WinTV and 8 & 13 to record via the HDHomerun. I’m thinking after a channel scan, you could drop 3 & 5 from the list on the HDHomerun and drop 8 & 13 from the WinTV. In effect, those channels are only available thru those devices, so Plex HAS to use those.
Is my thinking correct, or am I missing a flaw somewhere?
As long as you use one channel guide that sounds very reasonable.
