Record two programs at once with same tuner?
Is there a way to use PLEX to record two programs at once provided they are on the same primary channel? For example, record a program on channel 5.1 and 5.2 at the same time? I’m asking this because NextPVR allows you to do this, but doesn’t come with all of the excellent automatic metadata and organization you get from PLEX.
Plex sees those channels as two separate channels. As long as you have a device with two tuners you would be able to record two shows at the same time.
