Ubuntu: Migrated from Snapd/Plex to standard - 1 library won't play
Server Version#: 4.71.0
Just migrated everything from Snap.d/plexmedia server to the full downloaded version on Ubuntu. Everything has gone fine. Movies play great, all my metadata transferred over. But…
Everything in TV Shows gets a Error code: s1001 (Network) error. Well ok not everything but most shows.
Figuring its a database corruption issue from the move I deleted that library, created a new folder with a new name (TV Shows to TV Series) moved everything into that folder and created a new share hoping that would do it. Everything previews fine. Its seeing stuff. Plex even downloaded the right theme songs but I can’t get it to play. i’ve looked thru the log files but can’t see where the error is specifically. i’m stumped. Any thoughts?
Thanks in advance!
-Josh
@megladon88
Need the DEBUG logs ZIP file which capture it.
copy that gold leader will go thru the DEBUG ones and see what I find. THank you!
Don’t filter it. SEND . The force is not strong enough with you yet :slight_smile:
Ha! I appreciate it. I ran the database fixes from here and that got me right as rain… I’m not sure I waited long enough when copying everything over the other night so I think I corrupted my database. But again I’m back patched up and flying. (even after several reboots!)
(Repair a Corrupted Database | Plex Support)
thanks again for your help!!!
