UI Bugs and Feedback
Many thanks for the beta. It looks far better so far. Here’s some UI bugs and feedback. I would provide pictures but I no longer see the option for uploading in the forum. (Maybe make this a UI megathread?)
Version: 3.0.10-beta+sha.bfe01b53
Before sign in: The one time fee and store button is marked ???. Clicking the store button leads to an error.
Status headings: The lowercase status options do not match anything anywhere else.
Status friends list: The list items are indented randomly.
Settings > Help: Version text goes off-screen
Movies: If it can’t get the information, it’ll just display “Cast ,”
Will add more as I experiment. If you need log files, screenshots or more info, let me know. (I’m presuming that most of this won’t need that)
Taskbar icon is low resolution.
App version 3.0.10 Surface Pro 3
Thanks, will look into these @PCJonathan.
@mahesham22, It should match the quality of other taskbar icons (and the 8.1 Plex app). But anyway, it will be swapped for the normal Plex icon when we go live.
