UI Upgrade Defect - Please Resolve
New Bug - Fast Forward (FF)
When you press FF you no longer hear the click, which is not a problem except it makes you think you have not pressed the button. The real problem is when you lift off the button the show does not start. Occurs very frequently. You have to double click the FF and sometimes it starts. But also, In some cases the sound is not there when it stops. So you press FF again in hopes it fixes everything. Sometimes it does and other times it doesn’t. You have to just keep trying.
I have rebooted Roku and Plex when it provides the restart option, however, in the above case Plex did not offer a restart.
We can this be fixed as it worked in the previous version before the UI downgrade
