UK Freeview HD TV Guide
Hi
Quick question. Is there any way we can get a complete 14 day tv guide for Freeview HD in the UK? The only one that is available for UK is the YouView guide but that is missing a few channels and has additional ones that you don’t get on Freeview HD.
No. What we currently have is how you navigate it. I don’t know if it a licensing thing.
The navigation isn’t so much of an issue (although its not listing HD content, you need to select the SD one then restrict the channel to the HD channel number ie CH4 on 004 needs to be set to CH4 on 104) the problem is that the youview channel listings are not the same as the freeview HD ones so there are some channels you cant load into the EPG in Plex. I’m sure there must be someone out there who has an XMLTV link for the proper Freeview HD listings, just haven’t found it as yet.
