UK movie ratings
Hi, I would like my movies in Plex to use the UK rating system rather than US. I have changed the country for the Moviedb in the Agents setting and updated the library but it has made no difference. Am I missing something?
It would take more than a refresh, you would have to select Force Refresh I think.
I did this a year or two back where I changed from the US ratings to the UK ratings. Unfortunately the database is a bit patchy for many newly-released and less-known movies so I’m having to check the rating on imdb and then manually add it.
Thanks - has worked, but still with loads that still have US ratings.
