Una de mis bibliotecas ha dejado de aparecer en la pantalla principal
Una de mis bibliotecas, la que contiene las series de tv, ha dejado de aparecer en la pantalla principal. Está fijada pero no aparece. Si voy directamente a examinar esa biblioteca funciona con normalidad menos el apartado “Recomendado” que no carga. Por mas vueltas que le doy no se cual es el problema. En el log del servidor veo errores como este:
Dec 11, 2024 09:26:54.265 [19072] DEBUG - [Req#cfdd] HubCache: Retrieving ‘1/tv.recentlyadded.4/1/hubs/sections/4/esexternal-media,indirect-media,hub-style-list/count=12&excludeFields=summary&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1’ from the cache.
Dec 11, 2024 09:26:54.273 [19072] ERROR - [Req#cfdd] SQLITE3:0x7ff705d2b900, 14, os_win.c:48837: (87) winOpen(R:\Temp\etilqs_LTJwxyUKOiuHeNb) - El parámetro no es correcto.
Dec 11, 2024 09:26:54.273 [19072] ERROR - [Req#cfdd] SQLITE3:0x7ff705d2b900, 14, cannot open file at line 48838 of [a29f994989]
Dec 11, 2024 09:26:54.273 [19072] ERROR - [Req#cfdd] SQLITE3:0x7ff705d2b900, 14, statement aborts at 40: [select distinct metadata_items.id as ‘id’, parents.id as ‘parent_id’, grandparents.id as ‘grandparent_id’, metadata_items.added_at as ‘added_at’, metadata_items.library_section_id as ‘library_section_id’, grandparents.extra_data as ‘extra_data’ from metadata_items join metadata_items as parents on metadata_items.parent_id = parents.id join metadata_items as grandparents on parents.parent_id = grandparents.id where metadata_items.library_section_id in (4) and (metadata_items.metadata_type=4 or metadata_items.metadata_type=10) order by metadata_items.added_at desc limit 200] unable to open database file
Dec 11, 2024 09:26:54.273 [19072] ERROR - Got exception from request handler: sqlite3_statement_backend::loadRS: unable to open database file
¿Alguien sabe como solucionarlo?
Gracias y saludos!
Esto es lo que aparece en el apartado “Recomendados” pero solo de esa biblioteca. Las demás bien:
Me auto respondo. Ya lo he solucionado. Resulta que la carpeta temporal de windows estaba configurada en las variables de entorno en una ruta que ya no existía. La he modificado y ha comenzado a funcionar. Lo que no comprendo es porque solo afectaba a una de las bibliotecas en lugar de afectar a todas. En fin… solucionado.
