Unable to browse inside Individual TV Show Seasons.
Plex Sever - 2.4.3
OpenPlex - 0.5
Plex Home - Enabled
Affects: All Users under Plex Home
Description:
I can open the TV Shows Library, I can Navigate through all my TV Shows, I can open an individual show e.g Game of Thrones, I can view all the seasons, but when I go to press on one of the seasons I get "Trailers Unavailable". There is no loading cursor, this error message
immediately appears.
Everything apart from this works fine, movies are browsable and load fine. Also I can play TV Shows if they appear "On Deck"/
Attached PlexConnect.log
Things tried:
Optimising Library
Deep Scan
J-Holmes
Theme?
Theme?
CyberGhost84
PILBackgrounds: IOError: cannot identify image file <_io.BytesIO object at 0x1076dadd0> // url: http://10.0.1.60:32400/library/sections/2/all
How is the file(s) in question named? If you change the episode view does it work? Does it work on other plex clients? Is the show correctly matched in PMS (PlexWeb)?
Was working fine on other clients. All shows follow same naming structure and were matched in PMS.
Interestingly switching themes in OpenPlex seems to have kicked it into touch :)
