Hello
I’m trying to set up a plex server using the official docker image
Here is the command I’m using
docker run \
--name plex \
--network=host \
-e TZ="Asia/Bangkok" \
-e PLEX_CLAIM="__REMOVED__" \
-v $PWD/plex/config:/config \
-v /tmp/transcode:/transcode \
-v $PWD/media:/data \
plexinc/pms-docker
I’ve tried several times with varying configurations with no luck
Here is the debug output from cont-init.d/40-plex-first-run
Attempting to obtain server token from claim token
+ echo 'Attempting to obtain server token from claim token'
++ curl --verbose -X POST -H 'X-Plex-Client-Identifier: __REMOVED__' -H 'X-Plex-Product: Plex Media Server' -H 'X-Plex-Version: 1.1' -H 'X-Plex-Provides: server' -H 'X-Plex-Platform:
Linux' -H 'X-Plex-Platform-Version: 1.0' -H 'X-Plex-Device-Name: PlexMediaServer' -H 'X-Plex-Device: Linux' 'https://plex.tv/api/claim/exchange?token=__REMOVED__'
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 52.208.108.2...
* Connected to plex.tv (52.208.108.2) port 443 (#0)
* found 148 certificates in /etc/ssl/certs/ca-certificates.crt
* found 592 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_RSA_AES_128_GCM_SHA256
* server certificate verification OK
* server certificate status verification SKIPPED
* common name: *.plex.tv (matched)
* server certificate expiration date OK
* server certificate activation date OK
* certificate public key: RSA
* certificate version: #3
* subject: C=US,ST=California,L=Los Gatos,O=Plex\, Inc,CN=*.plex.tv
* start date: Fri, 10 Feb 2017 00:00:00 GMT
* expire date: Sun, 10 May 2020 12:00:00 GMT
* issuer: C=US,O=DigiCert Inc,CN=DigiCert SHA2 Secure Server CA
* compression: NULL
* ALPN, server did not agree to a protocol
> POST /api/claim/exchange?token=REMOVED HTTP/1.1
> Host: plex.tv
> User-Agent: curl/7.47.0
> Accept: */*
> X-Plex-Version: 1.1
> X-Plex-Platform: Linux
< HTTP/1.1 403 Forbidden
< Cache-Control: no-cache
< Content-Type: application/xml
< Date: Thu, 03 May 2018 10:37:17 GMT
< Referrer-Policy: origin-when-cross-origin
< Server: nginx
< Set-Cookie: _mkra_ctxt=ee2ca4644dda1f2b8e3affb179ffc4ab--403; path=/; max-age=5; secure
< Strict-Transport-Security: max-age=0
< Vary: Origin
< X-Content-Type-Options: nosniff
< X-Frame-Options: DENY
< X-Request-Id: d6dd5ad3-3c6d-4d24-9947-ddd27a5a7336
< X-Runtime: 0.017485
< X-UA-Compatible: chrome=1
< X-XSS-Protection: 1; mode=block
< Content-Length: 1
< Connection: keep-alive
{ [1 bytes data]
100 1 100 1 0 0 2 0 --:--:-- --:--:-- --:--:-- 2
* Connection #0 to host plex.tv left intact
I’m getting 403 forbidden from the claim API. I’ve tried several times, with different network settings, ensuring to build with an empty plex/config directory and not using cache from previous docker builds
I’m attempting to set this up on a Centos 7 dedicated server. I can provide additional details to help diagnose, but I’m really struggling to figure out why I’m unable to claim the server
The end result is, the docker container successfully runs, and I’m able to access the web ui, but I get stuck with “search for server” and I am missing the “server” option in the settings page.
Halp please
