Unable to display long playlists, Recently Added, or Artists in Android Auto
Server Version#: 1.14.1.5488
Player Version#: Android 7.11.3.9220
Phone: Samsung Galaxy S8 running Android 8
As of this week (and I did update my Android app a few days ago), the Android Auto interface is unable to display:
  • Long playlists (particularly smart ones based on genre that include hours of music)
  • Artists list
  • Recently Added list
I get the spinning wheel of death and then sometimes “No items” message.
Losing the display of long playlists and the Artists and Recently Added lists renders the Android Auto interface of Plex useless to me. I was using those features (particularly long playlists) often.
I have seen mention elsewhere on the web this is a known bug, but I am unable to find a lot of info about this issue tagged with android-auto on this forum. Has anyone been able to fix this problem after experiencing it?
FWIW, my music library is ripped by iTunes and has always had artist folder/album subfolders organization. About 70 GB of music. I have no problems using the features in question in the usual interface of the Android app, the iOS app, or the web interface.
Thanks for any guidance or answers.
Hi @alanpringle. In order to investigate the issue, would you mind sharing app logs? You can find them in Settings / Help & Support / Debugging/ Share debugging data.
Thanks in advance
Re-upload of logs. Think previous may have gotten corrupted. plex-log-alanpringle.zip (613.1 KB)
I have the same issues for a week or two. Recently played and recently added have the same problems.
I’ve been having these issues, too. The Android Auto app is buggy, but this recent regression has really caused me a lot of headaches :frowning:
Experiencing the same issue here.
Same for me!
Same here! It just spins and tries to load forever…
@jesusmc, quick update: timeouts still occurring with server v. 1.15.2.793 and Android app v. 7.12.2.9471.
Any information on when this might be fixed? Thanks for any updates you can provide.
Hi! Sorry to hear you’re experiencing problems with the Android Auto integration. In order to investigate the issue, would you mind sharing app logs? You can find them under Settings / Help & Support / Debugging / Share debugging data.
Thanks in advance
Logs were posted here.
Thanks,
is there any chance you could provide steps to reproduce? I mean, for example if the Android Auto is opened while Plex app is completely closed.
Thanks in advance
Did some quick video captures to show my experience. I was not getting these timeouts until I posted earlier this month.
This video shows starting Android Auto without Plex already open. I try to play a long smart playlist containing all songs tagged as Jazz, and it times out. I exit Android Auto and go to the Plex app, and the playlist opens with no problem.
In this video, the playlist is playing in the Plex app, and then I bring up Android Auto. Playlist does continue playing in Android Auto. However, when I try to bring up Artists list in Android Auto, get a timeout.
Even though I’m just using my phone for the screen captures, I get the same behavior when I plug in my phone to my car’s audio unit via USB.
The videos, BTW, are not searchable on YouTube. Have to use links above to see them. Hope they are helpful.
Thanks for pointing me out to those videos, they’re useful indeed. For what I see, infinite spinner is not only happening when loading “main” music section, it seems to happen when loading your playlists/artists/etc, right?
Would you mind grabbing logs right after you see the issue? I’ve checked the ones previously updated but unfortunately I didn’t see anything useful.
Thanks in advance
In regard to timeouts: they don’t occur on short playlist (60 minutes or so). Do on long smart playlists, Artists list, Recently Added, etc.
Attached logs were pulled right after I started Android Auto and played first songs in two short playlists. And then tried to display Artists and got infinity wheel. plex-log-alanpringle.zip (671.0 KB)
Just chiming in to say that I have the same issue. I have since reverted back to version 7.10.0.8875 and that has solved the issue for me. So something between that update and the latest updates seems to have caused the issue.
@Contragenesis, I just installed same version of the app you mentioned, and sure enough, the problem is solved for me. I will stick with that version until we hear from the Plex folks that the app issue has been resolved. Thank you for the quick fix.
Thanks to you also, @jesusmc, and I hope you can use the info here to pinpoint the change in the app that broke things.
So the only way to access the full artists list right now is to root the phone and downgrade android auto? :frowning:
Interesting, thanks for pointing that out. It’ll help me to investigate the issue.
You don’t need to root the phone. Just uninstall plex and install the version referenced above. It works as long as you don’t have auto update enabled in the Google Play Store.
