Unable to get GPG key via curl [SOLVED]
Hello,
I’m running LUbuntu 18.04, and following the guidance in the article
https://support.plex.tv/articles/235974187-enable-repository-updating-for-supported-linux-server-distributions/?_ga=2.1110392.897628164.1546872326-404803842.1542815356
but when I type the command:
curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
I get the message “Could not resolve host: downloads.plex.tv” and then “gpg: no valid open PGP data found”
When I add plex to the repository via the command:
echo deb https://downloads.plex.tv/repo/deb public main | sudo tee /etc/apt/sources.list.d/plexmediaserver.list
That works and adds plex to the repositories, so obviously the computer has no problem resolving the “downloads.plex.tv” location.
Two questions:
  1. Is there an alternate way to get the public key?
  2. I can download the file “PlexSign.key” from the “Enable repository updating …” link above. Is there a way I can point the system to that key?
[edit: I tried directly downloading the PlexSign.key file, and then importing it via:
gpg --import PlexSign.key
That told me that my keybox was create, and the public key “Plex Inc.” was imported. But then doing sudo apt-get update resulted in the same behavior as before, found the files, then returned “no public key” and would not continue the update.
/edit]
Thanks in advance for any help!
[Solution]
There is a newer function of apt which supports getting keys directly. So:
apt-key adv --fetch-keys https://downloads.plex.tv/plex-keys/PlexSign.key will correctly import the plex key.
Doing apt-get update seems to work normally, but now I’m getting a “Conflicting Distributions” error message.
Since my original problem was not being able to get the GPG key, and the apt-key method above works to import the key, I’m calling this [Solved].
Moderators: Consider passing this to the folks in charge of the “Enable repository updating …” page so they can add this as an alternative.
