Unable to hardware transcode on WebOS and PS5
Server Version#: 1.42.2.10156
  • OS: Ubuntu 22.04.5 LTS (Jammy)
  • Hardware: Intel 13th Gen i9-13900H (Iris Xe Graphics)
  • GPU drivers: i915 loaded, /dev/dri/renderD128 accessible, confirmedplex user in video and render groups.
Plex Media Server Logs_2025-09-20_13-55-09.zip (3.9 MB)
What I’ve tried:
  1. Verified GPU support (intel_gpu_top shows activity on other transcodes).
  2. Confirmed hardware acceleration is enabled in Plex settings.
  3. Confirmed permissions on /dev/dri/renderD128.
  4. Got AI to write some custom XML client profiles for LG and PS5 → same issue.
  5. Direct Playw and HW Transcoding work on my Android TV and Apple TV, but WebOS/PS5 force transcode and fail, then revert to software.
Two clients causing me issues
Sep 20, 2025 13:36:16.121 [140067378924344] ERROR - [Req#11ea8] Unable to find client profile for device; platform=PlayStation, platformVersion=11.60, device=PlayStation 5, model=PlayStation 5Sep 20, 2025 13:36:25.840 [140067576183608] ERROR - [Req#1209b/Transcode/p2pcfmms2aj7o1fivuoluxe0/920150e2-e0de-4f41-b001-483a10a46c60] [hevc @ 0x729ecf4cf940] First slice in a frame missing.Sep 20, 2025 13:36:25.840 [140067492940600] ERROR - [Req#120a1/Transcode/p2pcfmms2aj7o1fivuoluxe0/920150e2-e0de-4f41-b001-483a10a46c60] [hevc @ 0x729ecf4cf940] First slice in a frame missing.Sep 20,
Sep 20, 2025 13:13:37.255 [140067584682808] WARN - [Req#5790/Transcode/du9jpd9jgc1yfipy338e0j3t] Transcode runner appears to have died.
Sep 20, 2025 13:13:37.428 [140067462957880] ERROR - [Req#57d2] Unable to find client profile for device; platform=webOS, platformVersion=9.2.4, device=webOS 9.2.4, model=OLED55C4PUA.DCCQLJR
Sep 20, 2025 13:13:48.357 [140067462957880] ERROR - [Req#5a0a/Transcode/du9jpd9jgc1yfipy338e0j3t/09d2a9dc-a902-478b-97c3-6dc021f16f8b] [hevc @ 0x7d6898ed5940] First slice in a frame missing.
Sep 20, 2025 13:13:48.358 [140067492940600] ERROR - [Req#5a0c/Transcode/du9jpd9jgc1yfipy338e0j3t/09d2a9dc-a902-478b-97c3-6dc021f16f8b] [hevc @ 0x7d6898ed5940] First slice in a frame missing.
This is the file im trying to play
Media
Duration 2:45:49
Bitrate 57038 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
Part
Duration 2:45:49
File Dune Part Two (2024) Bluray-2160p.mkv
Size 66.04 GB
Container MKV
Indexes sd
Codec HEVC
Bitrate 51278 kbps
Language English
Language Tag en
D O V I B L Compat I D 6
D O V I B L Present true
D O V I E L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 7
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Location topleft
Chroma Subsampling 4:2:0
Coded Height 2160
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K DoVi/HDR10 (HEVC Main 10)
Extended Display Title 4K DoVi/HDR10 (HEVC Main 10)
Codec TRUEHD
Channels 8
Bitrate 3257 kbps
Language English
Language Tag en
Audio Channel Layout 7.1
Bit Depth 24
Sampling Rate 48000 Hz
Title Surround 7.1
Display Title English (TRUEHD 7.1)
Extended Display Title Surround 7.1 (English TRUEHD)
Codec AC3
Channels 6
Bitrate 448 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Title Surround 5.1
Display Title English (AC3 5.1)
Extended Display Title Surround 5.1 (English AC3)
Codec AC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Title Surround 5.1
Codec AC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Title Surround 5.1
Codec AC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Title Surround 5.1
Codec PGS
Bitrate 24 kbps
Language English
Language Tag en
Header Compression true
Display Title English (PGS)
Extended Display Title English (PGS)
Codec PGS
Bitrate 17 kbps
Language French
Language Tag fr
Display Title French (PGS)
Extended Display Title French (PGS)
Codec PGS
Bitrate 18 kbps
Language Spanish
Language Tag es
Display Title Spanish (PGS)
Extended Display Title Spanish (PGS)
Codec PGS
Bitrate 16 kbps
Language Danish
Language Tag da
Display Title Danish (PGS)
Extended Display Title Danish (PGS)
Codec PGS
Bitrate 18 kbps
Language Finnish
Language Tag fi
Display Title Finnish (PGS)
Extended Display Title Finnish (PGS)
Codec PGS
Bitrate 17 kbps
Language Norwegian
Language Tag no
Display Title Norwegian (PGS)
Extended Display Title Norwegian (PGS)
Codec PGS
Bitrate 17 kbps
Language Swedish
Language Tag sv
Display Title Swedish (PGS)
Extended Display Title Swedish (PGS)
Codec PGS
Bitrate 3 kbps
Language French
Language Tag fr
Codec PGS
Bitrate 3 kbps
Language Spanish
Language Tag es
@plotikai
You turned off DEBUG logging. This greatly impedes, almost prevents, diagnosing what’s happening.
I would appreciate you doing the following:
  1. Enable server DEBUG logging then SAVE the change
  2. Restart PMS
  3. Wait 3 minutes for PMS to startup and become stable
  4. Now recreate the playback failure
  5. Download the Logs ZIP file
  6. Attach the ZIP here
Sorry about that, but I think i figured it out. I set audio to 5.1 instead of trueaudio and it worked. Im guessing intel xe doesnt support audio transcoding and these clients dont support truehd
