Unable to remove Home User (no 'x' next to "Set PIN")
Server Version#: Version 1.18.4.2164
I know that I am not alone here, but seemed to have missed the solution. I would like to remove my “Home User” but cannot. I’ve tried different browsers, including incognito sessions, and still never see a remove option. Please assist.
Thanks,
Louis
You, as the server owner and admin, will always appear as a Home user there.
What is the real issue you are trying to solve?
Thanks. The real problem I am trying to solve is not having to select myself has the user when logging in
Each official Plex client has a checkbox in its settings named ‘Automatic logon’ (or similar). You should definitely try activating that.
Just took a look at your account. You are a member of someone else’s Plex Home. So you will be getting his list of users (of which you are one).
You were probably not aware when you accepted his invitation.
He used the button ‘Invite Home User’, when he should have used ‘Share Libraries’.
Go to the list of your “Friends” below and hover your mouse over this friend’s line.
https://app.plex.tv/desktop#!/settings/users-sharing
At the right end there will be a link ‘Leave Home’.
Are you able to see which friend it is? I have hovered over each person in my ‘users-sharing’ but do not see the ‘Leave Home’ link on any of them.
This should be done by now.
You might want to contact this user and re-establish your “Plex Friend” relationship, if you want.
Thanks so much for fixing this for me!
I had accidentally accepted someone else’s invite. It was driving me crazy. Thanks for the tip.
I also Join a friends home by mistake, I’m not able to remove him. He is now the admin of my plex account. How do I remove him?
I just had the same thing happen to my me, I invited a friend to my server, and now they are listed as the admin of my server? I have invited other friends to my server with no problems at all. But this is the first friend I have invited in 2020.
They aren’t the admin of your server. the text admin and crown mean the admin of the Plex home. Your friend invited you to his Plex Home and you accepted. to leave click the Red X at the right side of your user row when hovering over the row.
