Unable to see hardware transcoded stream after changing resolution
Server Version#: 1.22.2.4282Plex Media Server.log (379.0 KB)
Player Version#: Plex Desktop 1.30.1.2115-81e1fc3f
Plex web player: 4.54.5
I have been having an issue getting hardware transcoding to work on the linuxserver.io plex media server docker container. I have a Nvidia Quadro P1000 and I have it installed in my unraid server. I pulled down the docker container and made sure to add the --runtime=nvidia to the extra parameters and also downloaded the Nvidia Driver Plugin so that I could copy the GPU id to the Nvidia Visible Devices variable. I’m using v465.19.01 driver. I have set plex up and let it refresh the metadata of the files. I made the changes in the settings to allow allow hardware transcoding and I do have a lifetime plex pass. When I try transcoding the screen will flash a few times then throw this Playback Error: An unknown error occurred (4294967279)
Error code: 4294967279
Looking at the logs it looks like it’s having a hard time find the right codec. Other times when I play a movie it will transcode in hardware just fine at full quality. If I try to force it down to a lower level using either the browser or plex desktop app it will not continue playing and it will be just a blank screen. I’ve noticed however in the plex dashboard it shows the movies as continuing to play at the lower resolution even though the progress is not changing on the client.
Previously I was running the Plex Media Server docker container with intel quicksync for hardware transcoding just fine as I have a plex pass and I was able to pass the correct parameters to their docker container. I was not sure if that container would work with an Nvidia card so that’s why I’m using the linuxserver one. Previously I was transcoding to ram by using the host path /tmp mapped to the container path of /transcode.
