Unable to start Plex Connect
Unable to start Plexconnect which runs on Ubuntu..... atv running on latest version of firmware. Can someone please help me.
# ./PlexConnect.py
21:44:46 PlexConnect: ***
21:44:46 PlexConnect: PlexConnect
21:44:46 PlexConnect: Press CTRL-C to shut down.
21:44:46 PlexConnect: started: 21:44:46
21:44:46 PlexConnect: IP_self: 192.168.100.20
21:44:46 DNSServer: started: 21:44:46
21:44:46 DNSServer: Failed to create socket on UDP port 53: [Errno 98] Address already in use
21:44:46 PlexConnect: DNSServer not alive. Shutting down.
21:44:46 PlexConnect: Shutting down.
21:44:46 PlexConnect: shutdown
root@PlexMediaCenter:/home/alancarslaw/Library/Application Support/PlexConnect#
You got to shut down your Ubuntu-DNSServer...
dnsmasq is disabled - rebooted server still not working :(
cat NetworkManager.conf
[main]
plugins=ifupdown,keyfile
#dns=dnsmasq
[ifupdown]
managed=false
root@PlexMediaCenter:/etc/NetworkManager#
When access ATV trailers getting 'Trailers Unavailable' dns on ATV has been set to ip that plex connect runs on
Please read the sticky and provide the requested information to get further help.
What sticky new to all this?
https://forums.plexapp.com/index.php?/topic/69410-READ-BEFORE-POSTING
Can’t see guide for ubuntu unsure how to setup with new ATV - generate a certificate for PlexConnect and aTV how you do this on Ubuntu?
I have updated the sticky with a link to the newer guides:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide
The Linux one should help you. It also needs updating as it is now possible to install the certificate on your ATV by using PlexConnect and the ATV remote, see:
http://forums.plexapp.com/index.php/topic/82597-how-to-transfer-trailerscer-using-plexconnect-no-usb/
(make sure you read the whole thread).
Anyone able to help me getting this cert setup on ubuntu with ATV not sure how to go about doing it
Install Guide Linux (https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Linux) says:
Use the Mac Certificate Guide (https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Mac-Certificates).
Do the "Create the Certificate" and "Add the Certificate to PlexConnect" sections and follow http://forums.plexapp.com/index.php/topic/82597-how-to-transfer-trailerscer-using-plexconnect-no-usb/ - keeping in mind, that PlexConnect is up to that task, no need to change to code any more.
So I create the cert on the server that plexconnect runs on ie Ubuntu or can I run these commands on mac then transfer cert over to ubuntu?
As far as I know: You can create it on one machine and transfer it... But then, I never tried.
