Server Version#: 1.32.8.7639
I’m trying to update to the 64 bit version of the Plex Media Server but running the installer errors out while trying to uninstall the 32 bit version with Error code: 2, Error message: The system cannot find the file specified.
When I go to uninstall, it shows 2 older versions of the server (alongside the current one) that I can’t uninstall due to them missing the package caches for both of them. As far as I know, I can’t retrieve those older files, but Windows still refuses to remove them.
I think the 64 bit installer is trying to uninstall one of those two instead of the working one, but it can’t uninstall them.
Edit: I found how to fix the problem. I had to go into a legacy version of the windows uninstaller and it prompted to remove them from the uninstaller. Removing those non-existent old versions caused the server to be able to upgrade.
