Problems installing PMS 64-bit over PMS 32-bit
I am running into problems installing the 64-bit version of PMS over the 32-bit version.
This is the error I get when the 64-bit installer attempts to uninstall the 32-bit version of PMS:
I do see two versions of Plex Media Server in the app list:
I cannot uninstall PMS 1.32.2.7100 due to this error:
Is this situation preventing the PMS 64-bit installer from uninstalling PMS 32-bit?
If so, does anyone have any advice in resolving this?
Thanks much in advance!
Server Version#: 1.32.4.7164
https://support.plex.tv/articles/202967086-windows-errors-trying-to-upgrade-install-or-uninstall-plex-media-server/
RESOLVED…
I had to go into the registry under HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall and search on 1.32.2.7100…
Once found, I saved the Uninstall registry (precautionary measure) and deleted the key which removed it from the Apps & Features list.
I was able to proceed with upgrading to the 64-bit PMS.
