Server Version#: 1.70.2.3845-31e96af6
Player Version#: 8.20 (6066)
So I have, from time to time, had to remove already removed libraries from my pinned list in the past.
Over the past several days, I have had to do this nearly every time I’ve opened Plex and some times while still having the app open and just returning to the home screen.
Is this an issue that can be solved permanently or should I expect to continue to struggle with the problem going forward?
That’s a little confusing. Do you mean that, if you delete a library that is pinned, it’s still on the pinned list? Are the contents of the library still there? If not, then you’re probably seeing the same thing I reported here, and all you have to do is unpin the deleted library:
If you’re using Settings Sync, you may need to temporarily disable it, as Otto mentions in that thread.
It is an issue with the Apple TV that we are investigating. Basically it looses memory in device of what was pinned and then pins all libraries. I am closing this since other topic below covers it.
