Server Version#: Unraid 6.9.2
Player Version#: Docker Plex-Media-Server updated to latest version (it says up-to-date)
Hi all,
Since a few days, I am having an issue with my library in Plex-Media-Server. I have always added movies to my movie folder and Plex updates the library itself, to show the new movies. Since having added movies, it does not want to update the library. Not even after giving the command to scan the entire library. I have 914 movies in the library, but it doesn’t want to update - also tried refreshing all the metadata. All my movies are named “moviename (year) resolution.ext” with an .nfo file with a link to themoviedb for the movie and a jpeg with the movieposter, each movie is in it’s own folder, except for collection sets (Harry Potter, Lord of the Rings, The Hobbit, Fast and Furious, etc).
To do a test, I have made a new library in my Plex, which is pointing to the same directory as the one described above and the new movies do pop up there, so I know it’s not a naming issue. Strange thing is, it tells me there are 853 movies in there (vs 914 in the original). Because I thought this was very strange, I made another exact library, and in that one, I get 635 movies… Should all be the same number of movies, no? They should all be set up with the same movie scanner and agent as far as I’m aware.
Ideally I would want to keep “library 1 / the original”, as that knows which movies I have seen and which not yet and get it to update with the new movies.
I am using a docker “Plex-Media-Server” in Unraid since a few months now, ever since I was having issues with the Binhex-Plex docker (which is disabled/not running at the moment). (the Plex-Media-Server docker container is up-to-date too obviously).
Next to that, since yesterday, I am having an issue with another library which contains tutorials. I have set up the library as ‘other video’s’, scanner Plex Video Files with Agent ‘Personal Media’. The files show up just fine, in the ‘recommended’ section, and also in the library, but as I have many different files, I usually use the “folder” option, which always worked fine, but not anymore. As soon as I hit the “folder” in stead of the movie in library, I get a notice “Something went wrong” an unexpected error occurred. (sorry if naming is not 100% accurate, I am translating from Dutch.) I also made a new library, but get the same issue with the folders. I don’t understand as this has always worked great, all of the sudden, it doesn’t anymore…
A couple of days ago, I have put this problem on the Unraid forum too, but sadly haven’t gotten any reply yet…
Hope someone can help, as I didn’t find the answer on the forum.
Thanks in advance,
Best regards,
DrBobke
