Hello
I own a Triax TSS 400 SAT-IP server. With the older Plex Server versions, I was able to perform a channel scan with the device without problems and also watch live TV.
Currently, only the cable and antenna are displayed when setting up the DVR for this unit. Which makes no sense in the case, since the device is a pure Sat receiver. Can the support check this please and correct if possible in the next update.
Thanks Stefan G.
I’ve updated my Plex server to try out the new TV guide and I have lost a completely functional Sat>IP setup
Could we please add back in the custom/advanced option so we can setup Sat>IP devices as they worked really well prior to the update.
Support is back in the latest beta release
I have my 8 tuner SatIP Sat>IP server working just fine
@edddeduck Do you mind sharing the exact make and model of the SAT>IP device you are using, and confirm its still working well. I am in the market for a solution that is know to be working
thanks in advance
Damian
