Is anyone else noticing this? It's been going on for a while for me, the unwatched works correctly at the root of the show, but once you enter it and you see the season count the unwatched count is incorrect. It just says the number of episodes avail.
I'm not sure I understand, the unwatched count isn't even shown at the season level, only the total number of episodes is shown, so how exactly can it be wrong?the unwatched works correctly at the root of the show, but once you enter it and you see the season count the unwatched count is incorrect.
UPDATE:-
Ok, I think you're confused the number on the season list is the total number of episodes in that season, if it was the unwatched count it would say "Unwatched" after it and not "Episodes".
I've add the unwatched count now so grab the latest commit and see if you like it :)
UPDATE:-
Thanks Roidy, I just looked at the repo and I dont see the changes listed (I just see something in the last few hours for discover being changed) am I blind?
It is because Baa added a commit immediately after.
Yep, it’s there, baa made a commit just after me so his shows and not mine, but trust me it’s there.
If you drill down into github to assets/templates and look for Season_List.xml you’ll see a commit from 3 hours ago “Show unwatched count at season level”
Yep I see it, PERFECT! Thanks guys that really helps!
Thanks for this! I was actually just going to make this recommendation. This app gets better by the day!
