Update MKV Headers without Prompting Library Tasks
I’ve been revising / correcting MKV headers with MKVToolNix, which helpfully updates the tags without requiring any remuxing.
The issue that I am running into is that once I have updated the headers, Plex initiates all library tasks (generating markers, thumbnails, etc.) as if the file were recently added.
Is there a way to avoid this reprocessing of video files whose only modification is an updated header?
Server Version#: 1.43.3.10896
Player Version#: 1.115.0.426-4e960a1d
I’m guessing Plex is seeing the .mkv file with a newer modified date than it had previously and as such assumes it’s a new file.
There are tools you can use to modify those dates (like “touch”) so you could at least try and see if that’s the actual issue.
Editing the headers directly will only save you the effort of remuxing.
The affected file will still be treated as “modified”.
