Server Version#: 1.23.1.4602
I ran this via command but it still shows I have an update. This is the first update Im trying to do via command but its telling me to insatll manually however I run my server on linode not my own computer so I need some help getting up to date
Can you show me your command line attempt(s) / where you’re at in the process so I can guide you?
As for having updates available (showing in Plex/web).
- Settings - Server - General - Show Advanced
- It will tell you which channel it’s monitoring. You want “Public” to match the Repository (if that’s your intent)
