Updating Library
TO whom I might offend, I apologize. This has got to be the worst app I have ever used in my life. Its one big convoluted POS. Sure it may be fine for the tech savvy fol;ks out there who don’;t mind reading through page after page of documentation, but most people are looking for an easy simple way to watch their ripped movies from their PC or network on their TV. Obviously you can do that with PLEX, butg when a problem arises for instance, You rip a new movie and then spend two weeks trying to get it to appear in your library. It should just appear. And yes I’m sure I’m not doing something right, but thats just my point. Can I eventually figure it out? Of course. Do I want to spend more than 5 minutes trying to figure it out? No. PLEX may be powerful for advanced users, but simple and user friendly it is NOT. For all of you tech wizards out there I hope you get lots of use out of PLEX and i hope that the company who makes PLEX makes millions and billions of dollars and becomes extremely successful. In the meantime, I will be off looking for a simple solution to watching the 1000+ movies I’ve spent the last 6 years ripping to my hard drives. Thats all a lot of us wish to do.
Well I have never had the problems you enumerate. I rip a movie or TV show name ti correctly and place it in the proper structure and it just appears.
95% of the time naming is the problem:
For movies it should generally be “Movie Name (year) .ext” See:
https://support.plex.tv/hc/en-us/articles/200381023-Naming-Movie-files
and
For TV it should be “ShowName - sXXeyy - optional episode name.ext” See:
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Based-TV-Shows
If you follow those and your structure also conforms then you should have very few problems.
Be aware that you need to name your files exactly as they are in the databases as well.
