Updating Network info in Guide
In the Fresno market two stations have swapped networks. KAILDT4 (7.4) WAS COZITV, it is now ION Television. KNSODT3 (51.3) WAS ION and is now COZI TV. In the DVR’s guide, 7.4 is still shown as COZITV, but the listing are coming through for ION, which is fine. However, 51.3 is shown as ION and the listings are still coming through for ION. So, in effect I have no way to record anything on COZI TV (51.3) because the guide doesn’t contain any COZI TV listings. How does one get word to the Guide provider of the change for COZI so it’s listings will show up on my local 51.3? By the way, if I tune to those two channels directly (i.e. on my television set) the guides being broadcast by each station OTA are correct (i.e. 7.4 is broadcasting ION’s guide while 51.3 is broadcasting COZI’s guide).
One other point … apparently there is no way to directly record a time period on a particular channel unless the Guide contains valid data for the station/program you want to record, right? In other words, you can’t set up a manual recording, right?
Thanks, Chuck
